Gas tank anti speak pads on straps. - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    I'm replacing my gas tank with a new Quanta tank and straps and I need to know if anti-squeak pads go on the straps or not. The old one I took off has the pads on the straps but I have been told the pads only goes on the braces that support the tanks but the straps should not have pads. Please give me some advice.
  • Mike F.
    • April 25, 2011
    • 668
    Re: Gas tank anti speak pads on straps.
    I replaced my 70 tank a few months ago. Nothing on the straps. Anti-squeak pads were only on the under tank cross members.
    Have you read this thread?
    https://www.forums.ncrs.org/showthre...ti-Squeak-Pads
    Mike
    • Brandon T.
      • October 23, 2008
      • 872
      Thanks Mike, mine is a 68 and looked like the correct straps and tank but the straps had pads. Both Quanta and Paragon told me no pads go on the straps.
      • Kenneth H.
        • October 27, 2008
        • 500
        Brandon, I replaced my tank about 18 months ago, and mine was the same as Mike's.
        • Brandon T.
          • October 23, 2008
          • 872
          Thanks Kenneth, my car is a November 68 car. Maybe they quit putting them on the straps.
          • Michael M.
            • February 15, 2007
            • 455
            My '68 (November 67 build) did have pads on the straps when I changed out the gas tank a few years back.
            • Brandon T.
              • October 23, 2008
              • 872
              Did you put the pads back on when you replaced the tank? Is your car a Big Block?
              • Michael M.
                • February 15, 2007
                • 455
                Like the others on this thread, they were completely deteriorated. I couldn't find anything I liked so I bought something from home depot about the same thinckness and used it, but it wasn't tar paper or anything. My car is not judged, so I put something in there that approximated the thickness and provided some cushion but wasn't too compressible. I used the yellow weatherstrip adhesive to glue it on. My car is a big block.
                  Brandon -
                  What does the Assembly Manual show in UPC 8?
                    • 43279
                    Brandon -
                    John------
                    It shows no anti-squeak pads on the straps and no indication of any revision removing said pads.
                    • Brandon T.
                      • October 23, 2008
                      • 872
                      Looked at Dr.rebuild catalog and it shows pads for the staps. Item# 3002216 and has another number for the pads that goes on the cross braces that holds the tank up. I have decided to order them and put them on since my old straps had them.
                        Brandon -
                        Do whatever you like, but the car was built to the Engineering specs in the Assembly Manual, not to the Doc Rebuild catalog; 12 of the 13 major '67-'69 Camaro parts houses also sell insulator strips with their gas tank strap kits, and not one Camaro was ever built with them.
