396 fan identification - NCRS Discussion Boards
  • Bob P.
    • March 5, 2007
    • 38
    Can anyone tell me if the 396 fan has a "W" stamped on it?
    • 43222
    Re: 396 fan identification
    Bob-----
    I am reasonably sure that it does not have a "W" (or, any other character).
    • Bob P.
      • March 5, 2007
      • 38
      Joe
      I tend to agree with you. My fan does not have one, however, I was in Kissimmee last month and one of the judges believed it should.
        • 43222
        Joe
        Bob------
        Actually, I believe the fan blade assembly with the "W" is the GM #3770529 which was used on most 1961-67 small blocks. It is a very common fan and, in fact, is still available from GM. I don't know that it still carries the "W" manufacturer's ID or other nuances of original configuration. As a manufacturer's ID, the "W" may be found on other fan blade assemblies, too, but I don't think the 1965 L-78 fan is one of them.
        • Wayne M.
          • March 1, 1980
          • 6414
          Bob------
          FWIW, the '529' fan (pic below, on bottom) does not have the 'W'. It is from either '65 #101xx or '64 #086xx; notice the round (mushroom) head rivets. Neither does my A/C 7-blade '943' have any stamping on the rear spider arms (also mushroom rivets, off a '64).
          I almost shouldn't even mention the following, as it pollutes the original poster's question, but the top fan assy. I show is possibly a "hybrid" (circa 1971) service unit with the spider used on '66-up '3888366' [with the 'W'] but with the shorter blades of the '65 L78 #3872792 (to give nominal O.D. of 17.0").
          I took the attached pic to show the different angle of the blades on the big block fan (top) with the small block '529' (bottom).
          r
          • Jaime G.
            • April 1, 1988
            • 480
            No W on original fan blade unit for L78
            • Bob P.
              • March 5, 2007
              • 38
              Wayne
              So are you saying the 3872792 does have a "W" like the 3888366? Is it manufactured by the same company, in the same profile with a smaller outter diameter?
              Bob
              • Bob P.
                • March 5, 2007
                • 38
                Thanks to all.
                I'm glad I didn't go and ruin a perfectly good fan by trying to stamp a "W" on it.
                • David L.
                  • July 31, 1980
                  • 3310
                  According to my research over the last 25 years this is what I have found.
                  3770529 fan (1960-1967)
                  17 1/8" dia., 1 5/8" pitch, 4.00" by 5.68" blade
                  stamped "H" on front, "W" on rear (my original 1966 fan w/flat rivet heads)
                  3872792 fan (1965 w/396)
                  17" dia., 2 1/8" pitch, 4.00" by 5.68" blade
                  no identifying marks on ctr. hub
                  3888366 fan (1966-1967 w/427, 1968-1970 wo/AC)
                  17 1/2" dia. , 2 1/8" pitch, 4.00" by 5.93" blade
                  stamped "FRONT", "H", and "66" on front
                  All 3 fans were made by Hayes-Albion with 3" BC and 2 3/8" hub hole.
                  Dave
                  • Bill W.
                    • March 1, 1980
                    • 2000
                    Sorry to be the odd man out but my fan from st louis built 17346 31.000 miles has a heavy H stamped on the front side of the spider in the bolt area and a very light stamped W on the rear side by the rivets . It also has the flat rivets and is 17" My fan from #16120 is very rusty but has a heavy stamped H on the front and is to pitted to see anything on the rear . It also is 17" and has round top rivits .
                    • David L.
                      • July 31, 1980
                      • 3310
                      Bill,
                      Does the pitch measure 1 5/8" or 2 1/8"?
                      Dave
                      • Bill W.
                        • March 1, 1980
                        • 2000
                        Dave my rusty fan is bent so I cant get A pitch . the one from 17346 is exactly 17" dia. Laying it flat on a table it has a 2 1/8 pitch . The blades are 5 5/8 long. and 4' on the long side & 3 3/4 across the rear side .It has flat rivits and is stamped H with the word Front on the front . and a light W on the back side .Everything is the same as my rusty one except the word front and the rivits. Bill
                        • Tony S.
                          NCRS Vice President, Director Region VII & 10
                          • April 30, 1981
                          • 988
                          Bill. My July 29, 1965 L78 car had the same fan as you have described. H in the front, light W in the back. I'd like to know if these features appear on Jody Balch's (formerly Gene Leonard's) car. Jody's car is earlier than my L78 car though. I'm not sure if that makes a difference.
                          Tony
                          Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
                          Original member of the Kansas City Chapter, est'd 07/11/1982.
                          Member: 1965 and 1966 National Judging Teams
                          Judging Chairman--Kansas City Chapter.
                          Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
                          • Wayne M.
                            • March 1, 1980
                            • 6414
                            A few pics so that we're all on the same wavelength as to stampings; the 'W' on the back of an arm of the spider. 'FRONT' (amazingly) on the front, hence not visible during judging because of the fan clutch, and the heavy "H", and finally the '66'.
                            b
                            • James W.
                              • December 1, 1990
                              • 2658
                              396 fan pictures from 1965 396 VIN 22161.
                              James West
