67 WS Wiper Arm Installation - NCRS Discussion Boards
  • Al R.
    • June 30, 1988
    • 688
    When installing the wiper arm passenger rod onto the motor shaft, does it matter whether the passenger side transmission is pointed up or down so long as the rod attaches to the motor shaft? I'm unsure if there would be an interference fit with car body or if there would be an issue with the blades working properly. I'm hoping to get this back together today. TIA Al
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 67 WS Wiper Arm Installation
    Yes it does. Passenger side should be down.
    • Al R.
      • June 30, 1988
      • 688
      thanks Russ. I'll nget back on it as soon as I get my headlight motors in
      • Stephen L.
        • May 31, 1984
        • 3162
        I'd suggest that you have the short arm welded to the wiper shaft, where it is now swagged. This results in a "tighter" wiper system. These are usually worn from use.
