Popping Sound through Exhaust - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    My '69 has a "background" pop-pop-pop through the exhaust at idle. I have '69 sidepipes so it's very pronounced. Does this indicate a leaking valve or something similar? Don't remember if it's on both sides but it's definitely on the driver side.
    Jack
    Jack Ottofaro
    • 43293
    Re: Popping Sound through Exhaust
    Jack
    Jack------
    Do you have an operating AIR system?
    • Dick W.
      • 10483
      Put your had near the exhaust and see if it keeps pushing against your hand or does it allow your hand to go back toward the pipe,IE pressure against your hand, and it almost seems that it sucks your hand back toward the pipe, on occasion.
      Dick Whittington
      • Jack O.
        • July 31, 1996
        • 527
        Joe,
        No AIR system. Exhaust manifold holes are plugged - bought them that way.
        Jack
        Jack Ottofaro
        • Jack O.
          • July 31, 1996
          • 527
          Thanks. I'll try that. If it does not keep pushing what does that indicate?
          Jack Ottofaro
          • Dick W.
            • 10483
            Dead cylinder, could be plug, wire, valve, etc At least you will know which side to start looking for the problem
            Dick Whittington
            • Stuart F.
              • August 31, 1996
              • 4676
              If you have a dead cylinder, wouldn't you also notice a loss of power? Also, does it only occur at idle or would you also notice at POT or WOT?
              Stu Fox
              • John D.
                • June 30, 1991
                • 875
                I would also see if you have the popping right after a run on the highway...if not that could indicate plug fouling at idle
                • Doug M.
                  • January 1, 1991
                  • 68
                  carb set to lean will do that
                  Doug
                  • Jack O.
                    • July 31, 1996
                    • 527
                    Thanks for the responses everyone. Another "symptom" is that when I first start the car it simply reeks of gas fumes (it's an L71 however not with the original cam and with 1x4), compression very low because it was originally built with 6-71 blower). If I start it in the garage even with the windows and doors open my clothes and hair will also reek of gas fumes. Could this somehow be correlated with the popping as a clue to what the issue is?
                    I read on the net about leaks at the exhaust manifold causing a popping. I certainly don't hear or feel any apparent exhaust manifold leaks.
                    Jack Ottofaro
                    • Thomas H.
                      • August 31, 2005
                      • 1068
                      Doug
                      Had this problem on my 60, but it was an overly rich mixture causing it. Metering rods in carb were not fully seating at idle.
                      Tom
                      2007 Z06, Lemans Blue
