60 Fan Clutch, 3916141? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 942
    Will the GM 3916141 fan clutch work on a 60 corvette? I believe I have an origional clutch that needs rebuilt, but I thought it woud be safer to use a new clutch and loose 1 or 2 point in judging?
  • Al E.
    • September 5, 2011
    • 313
    Re: 60 Fan Clutch, 3916141?
    William,
    I have replaced my clutch fan about 5 months ago. I bought a new one from GM and it did not mount up, then I used one from Autozone and it was like magic. It did the job. I am not sure if you are seeking a functional unit or a GM brand unit.
    Al
      • 43248
      William------
      Assuming that the rest of your components are original or configured the same as original (i.e. fan, pullies, and waterpump), the GM #3916141 will work just fine for you. It has a shaft length that is slightly shorter than your original clutch but it will work fine. In fact, it is, by far, the best replacement fan clutch available today for your application. I recommend it.
      • William B.
        • April 30, 1975
        • 942
        thank you, will order the gm fan clutch tomorrow!
