Trevor Jones - 1959 Vacumn Operated Co-ordinated Washer Operation Information Request - NCRS Discussion Boards
  • Trevor J.
    • June 2, 2011
    • 9
    C1 59 Corvette. Vacumn operated - Co-ordinated washer.
    I would like to know how they work. Is there a fault finding system for them. Is there a full breakdown view of how they work.
    We are in Australia. Any help would be wonderful. I can not find any information in any of the manuals. Thank you.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17696
    Re: Trevor Jones - 1959 Vacumn Operated Co-ordinated Washer Operation Information Req
    Trevor,
    Do you need information on the electrical motor or the vacuum system?
    ST12 has good information on the wiper motor.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • John F.
      • March 23, 2008
      • 2409
      You may want to search. I think Tom Maxwell did a writeup about the w/w system. Maybe someone will do another one.
      • Jimmy J.
        • May 31, 1988
        • 304
        Will this help? http://www.chrysler300club.com/tech/w-washer60.html
        • Christopher R.
          • March 31, 1975
          • 1599
          Tom Maxwell will rebuild it for you for under $100 USD. There's a diaphragm in there that is supposed to hold a vacuum and cause the rod to move. Tom can open it up; replace the diaphragm; and, put it back together.
          You can test yours by applying a vacuum to the nipple. The vacuum should hold and cause the rod to move. If nothing happens when you apply vacuum, then the diaphragm needs replacing.
          Tom Maxwell
          Capital Auto Restoration
          301-948-9481
          tmax61@hotmail.com
          • Trevor J.
            • June 2, 2011
            • 9
            Thanks Gary, I need to know the vacuum system, how to test it and how it operates. Thanks Trevor.
            • Trevor J.
              • June 2, 2011
              • 9
              Thanks Christopher, Will try testing it this morning. Thanks for your help and you time. Regards Trevor
              • Trevor J.
                • June 2, 2011
                • 9
                Thanks John, One of the members has just sent through a site www.chrysler300club.com/tech/w-washer60.html which has a great article on the very assembly we have. Thank you for your time. If the diaphragm is the problem we will get in touch with Tom Maxwell. Thanks for your input and time for this. Regards Trevor
                • Trevor J.
                  • June 2, 2011
                  • 9
                  Morning Jimmy, Thank you for you help in this matter. The write up y Dr Tony Rinaldi on that web site is a great help and should be just what we need. The pump is identical to mine. Thank you for your time so appreciated. Regards Trevor
