Judge my engine bay ....I can take it.... - NCRS Discussion Boards
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Judge my engine bay ....I can take it....
    Battery is unhooked.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Jack P.
      • March 19, 2009
      • 1135
      I would not know.....look on firewall.............right hand side....and not the master cylinder cover....
      Jack
      • Jack P.
        • March 19, 2009
        • 1135
        #18
        For safety.......
        • William C.
          • July 15, 2009
          • 239
          #19
          Jack..Alternator isn't clocked correctly. The + cable should be at 12 o'clock. Then your wiring will be correct and the white tab will go in the hole to secure it...Bill
          (That would be correct for 67 and I think for a 66.)
          • Russ S.
            • April 30, 1982
            • 2163
            #20
            Looks like the dip stick is chrome, cyl numbers are written on the valve covers, and this one I am guessing at but is that long curved alternator adjustment brace correct?
            • Jack P.
              • March 19, 2009
              • 1135
              #21
              Dip stick is correct for 66 L 79 numbers on cly will come off.......Bracket is correct ? I have not changed in 42 years.. Can alt. be fixed ...I know it is wrong....right one died a few months ago....... or do I need a more correct one.......
              Still missing item on firewall driver side.........look very close......
              Jack
              • Jack P.
                • March 19, 2009
                • 1135
                #22
                correct ....they go on valve covers 350 HP middle and HT on ends of covers
                Jack
                • William C.
                  • July 15, 2009
                  • 239
                  #23
                  Jack..Shouldn't be RED GM on heater hose. No clamp required on overflow hose. Throttle return spring should go into the throttle rod hole..Bill
                  • Joe R.
                    • July 31, 1976
                    • 4552
                    #24
                    Jack,
                    Just a few observations
                    1. Thermo Housing needs paint
                    2. Battery Cables wrong
                    3. Hose position, heater
                    4. OF Tank Cap, rusty
                    5. Exhaust Manifolds need overspray
                    6. Water Pump Pulley not orange
                    7. Fan Clutch using bolts??
                    8. Radiator
                    9. Hood Latch Spring needs paint
                    10. Exhaust Pipe Aluminum Cover?
                    11. Hose Clamps
                    12. Brass Plug in Manifold
                    13. Air Cleaner Element
                    14. Exhaust Locks??
                    If pics were more detail there should be another 20 or so things wrong.
                    Enjoy
                    JR
                    • Scott S.
                      • September 11, 2009
                      • 1961
                      #25
                      Jack,
                      Shouldn't the fuel pump to carb line be chrome in '66?
                      • Jack P.
                        • March 19, 2009
                        • 1135
                        #26
                        Originally posted by Scott Smith (50839)
                        Jack,
                        Yes....my correct fuel pump failed on my 48 state trip........I put on a replacement on the road and needed to make a new line
                        I have rebuilt the pump and have the orignal chrome fuel line...... the question is
                        Use my correct rebuilt pump and line..........I will drive over 10,000 miles this summer or
                        Leave on the replacement pump that has gone 31,000 miles in the last 18 months......
                        That is the problem that I and others face when we use the car as a daily driver .....and still like to keep it as stock as possible..
                        I appreciate all the comments..........some of the changes I will make......others are not practical for my use of car...
                        Jack
                        • Jack P.
                          • March 19, 2009
                          • 1135
                          #27
                          Thanks for all the items. Some are practical for my car use and some are not.........
                          As I mentioned , I will drive my car over 10,000 miles this summer and drove 30,000 plus over the last 18 months.....
                          Hard to keep engine area clean......... and correct over reliable ...... is very important when the car is a daily driver.....
                          I will post pictures next week with some of the changes.....
                          Jack
                          • Jack P.
                            • March 19, 2009
                            • 1135
                            #28
                            Do you mean the hole in rod that the carter pin is in , keeping the rod attached to the carb throttle leaver ?
                            • Jack P.
                              • March 19, 2009
                              • 1135
                              #29
                              Hi, my old alt. fit perfectly with pin going in hole....I put this replacement on this fall and noticed that it did not line up right as you suggest.
                              Can the alt. be clocked..? Just take out the four screws and rotate it ....like you would do with a fuel pump.......
                              or do I need to find a proper replacement alt.
                              thanks
                              jack
                              • William C.
                                • July 15, 2009
                                • 239
                                #30
                                Jack..Yes, there wasn't a cotter pin used the spring goes in the rod hole. There are other threads on this..Bill
