Restoring a duel snorkel air cleaner - NCRS Discussion Boards
  • Lyndon S.
    • April 30, 1988
    • 1027
    My air cleaner base need restoring. What would be the best paint to restore that high gloss back with? Would something out of a rattle can give good results if it was high heat? Pros and cons of powder coating parts? I know powder coating will not pass judging, but I would like that part to last more than I am worried about losing points. Has anyone restored one with the powder coating process? If so were you pleased with the results. I think I can have it blasted and powder coating for like 85 dollars.
  • Tom L.
    • October 17, 2006
    • 1439
    Re: Restoring a duel snorkel air cleaner
    When I cleaned up my air cleaner I stripped it with paint stripper, seems it's plated. Wouldn't have found that out if I beaded it. Sprayed it with a rattle can, looks good. I've driven the car a few thousand miles since, the only thing that showed signs of wear is the white GM sticker on the drivers side. It wrinkled a bit. Don't know if that's a result of something I did, quality of the sticker itself or just normal. Good luck!!
      • 15600
      Gee there is nothing wrong with my 42 year old air cleaner base. What do you guys do to your air cleaner assemblies to damage them so that they need refinishing?
      • Tom L.
        • October 17, 2006
        • 1439
        Can't speak for Mr. Sharpton but the previous owners of my car didn't have the words, "correct" or "neat" in their vocabulary. There must have been a case or two of black rattle cans arond. I think they used them to "restore" anything that looked remotely close to black or had any black on it. In the coming weeks I'll be working on removing the black paint from the vacuum lines, wires, etc... can't wait!! It's not easy being the 2nd, 3rd, or 4th owner of these cars.
        • Lyndon S.
          • April 30, 1988
          • 1027
            • 15600
            Originally posted by Lyndon Sharpton (12791)
            I don’t know I guess it’s the heat from the BB under the hood. But some of the paint on mine is pealing off one of the snorkels.
            Lynn what type of paint did you use? I found some Rustoloem in a high heat gloss that I am thinking about using.
            Yea, that's it -- it's those nasty big blocks. I should have known that.
            • Lyndon S.
              • April 30, 1988
              • 1027
              • Michael W.
                • April 1, 1997
                • 4290
                I don't think the air cleaner base or cover had true 'high gloss' paint to start with, semi-gloss would be closer.
                  • 15600
                  Depends how often you wax it Mike.
                  • Tom L.
                    • October 17, 2006
                    • 1439
                    Stop picking on our engines!!! So what they're a little fat, we like em that way.
