Help running a compression test with transistor ignition - NCRS Discussion Boards
  • Dan H.
    • September 5, 2011
    • 40
    I am burning oil on an LT-1 in cylinder #2. I need to run a compression test and have the original TI. Is there anything special i need to do so that I don't damage this ignition system? I have heard that I need to ground the dist end of the coil wire to prevent damage. Is this all I need to do? Is a simple wire with alligator clips enough to handle the current?
  • Dick W.
    • 10483
    Re: Help running a compression test with transistor ignition
    Just disconnect the ignition system.
    Dick Whittington
    • Dan H.
      • September 5, 2011
      • 40
      What is the best/easiest way to disconnect it?
        • 15625
        After you figure out what to do to the ignition you might consider doing a cylinder leak down test. The compression test is better than nothing, but a cylinder leak-down test will tell you more. You might be able to borrow the cylinder leak-down tester from Auto Zone or Advance/Cragen/O'Riley's. You will need access to compressed air to use the cylinder leak-down tester.
        • Patrick B.
          • August 31, 1985
          • 2009
          I ground the distributor end of the coil wire with an ordinary (16-18 ga) alligator clip lead on my 70 LT-1 when turning the engine over for a compression test or to build up oil pressure after an extended storage. It still has the original amplifier which works fine after almost 42 years.
          • Michael H.
            • January 29, 2008
            • 7477
            Dan,
            The best/easiest/safest way to kill the TI is unplug the amplifier.
            • Dan H.
              • September 5, 2011
              • 40
              Thank you for the help guys! I'm not familiar with a leak down test, I have heard them talked about in other forums but I'll have to do some research to see whats involved. My main goal is to not cook original parts!
              Dan
                • 15625
                Google is your friend. I have selected just one Video. There are explanations of "how to build your own" and on and on:
                • Joe R.
                  • May 31, 2006
                  • 1822
                  Terry,
                  I've often wondered how to run a leak down test. Thanks for posting that video, it was very informative!
                  Joe
