'69 Heater Control Panel - NCRS Discussion Boards
+ More Options
Posts
  • G A.
    • February 18, 2010
    • 229
    No A/C. There is a 4 port vacuum switch under the left control knob and it leaks in all four positions. I cannot locate an identical replacement.
    Unless someone knows where I can get one, will the 9 port vacuum switch intended for A/C cars work?
    If so, do I need to block the unused ports??
    Is there another solution??
    Any help is appreciated!!
    Dan
    • 3416
    Re: '69 Heater Control Panel
    Hi Dan,
    Perhaps you could try Gee Auto Sales in Middlebury Center, Pa. (Google). for a used non a/c vacuum switch. Gale Gee, the owner, is a pretty nice guy.
    Good Luck!
    • G A.
      • February 18, 2010
      • 229
      Thanks Alan!! I'll try them. Strange how you can find the switches for A/C cars but no one reproduces them for non-A/C cars.
      Dan
