69 Wiper Blade Insert Detailing - NCRS Discussion Boards
  • Wes G.
    • December 1, 1999
    • 99
    Was the metal strip in the 69 wiper blade insert blacked out, partially blacked out or left shiny?
    The 68-69 TIM & JG (p. 26) makes no reference to this strip.
    However, the 70-72 TIM & JG (p. 40) states "The wiper blade insert should have no bright metal in it."
    Wes69 Wiper Blade Insert_RH_AF_08.pdf69 Wiper Blade Insert_RH_AF_010.pdf69 Wiper Blade Insert_RH_AF_011.pdf
    • 15616
    Re: 69 Wiper Blade Insert Detailing
    Wes[ATTACH]37043[/ATTACH][ATTACH]37044[/ATTACH][ATTACH]37045[/ATTACH]
    I expect 1969 was the same as 1970, but I have yet to see a 1969 with original wiper blade inserts. Maybe someone here has one, and will speak up.
    • Ralph S.
      • February 1, 1985
      • 935
      Just went to the garage to look at my 45,000 mile 69 that i have owned since 1978 and the insert on the rubber blade is black
      • Mark D.
        1984-96 Team Leader
        • June 30, 1988
        • 2157
        It has what I would call black goop coating. That is to say I'm not sure what it is. I apologize, this is a bad pic so I'll try to get a better one later...
        Kramden
          • 43250
          Wes------
          Black.
            • 43250
            Terry-------
            I have one. I have never changed the wiper blades or inserts on my car since day-one.
            • Mark D.
              1984-96 Team Leader
              • June 30, 1988
              • 2157
              Here is a pic of the previously mentioned goop...
              Kramden
              • David L.
                • July 31, 1980
                • 3310
                I have a pair of original 70 Camaro SS350 18" black chromium Trico wiper blades with original rubber inserts (assume to GM # 8798506).
                The rubber inserts have "U.S. PATENT 2697241" molded on the rubber. The metal reinforcements are dull black with 29 "loops".
                I also have several sets of NOS Trico RF-18 inserts (aka refills) that have the same "U.S. PATENT 2697241" molded on the rubber but the metal reinforcements are plain metal with 29 "loops".
                I have a pair of satin 16" Trico blades removed from a 1970 Pontiac LeMans convertible ("LT" on glass = May 1970) back in the early 1990's. The plain steel reinforcements have 25 "loops" (24 small, 1 large) and still have remnants of the rubber insert.
                I have a pair of NOS 9872322 18" black chromium wiper blades (first used on 1971 models) that are the same as my original 70 Camaro SS350 blades mentioned above EXCEPT that the dull black reinforcements do NOT have the "loops". GM # 9872322 replaced GM # 8798506 in Aug. 1971 as per Chevrolet Parts History.
                Dave
                • David L.
                  • July 31, 1980
                  • 3310
                  Mark,
                  I have collected hundreds and hundreds of Trico wiper blades at junk yards and swap meets over the last 30 years and have never seen any wiper blade reinforcements with the "black goop coating".
                  Dave
                  • Mark D.
                    1984-96 Team Leader
                    • June 30, 1988
                    • 2157
                    These discussions help us get the bottom of things. It surely would help if you and Joe could post clear pics of one or two of yours. I'm ready to learn...
                    Mark
                    Kramden
                      • 43250
                      Mark
                      Mark------
                      My problem is that my car is not running yet and I have no battery in it. So, I can't open the wiper door and can't move the wipers to an observable position. I don't really want to use the manual wiper door opening method.
                      • Mark D.
                        1984-96 Team Leader
                        • June 30, 1988
                        • 2157
                        Joe,
                        I'm surely not in a position to sling mud at someone for not getting their car finished.
                        Mark
                        Kramden
                        • David L.
                          • July 31, 1980
                          • 3310
                          Mark
                          Here are some not so great photos. The black on the NOS 9872322 (1971 vintage) reinforcement seems to be very fine "goop" unlike the 1970 dull black reinforcement.
                          Dave
                          • Mark D.
                            1984-96 Team Leader
                            • June 30, 1988
                            • 2157
                            Dave,
                            Those are excellent pics!
                            The pic I took of mine is with a high powered lens which probably shows too much detail. I believe the coating/finish on yours is the same as on mine. I'll take a pic of mine with another lens tomorrow which may compare similarly to yours. I guess my point is, it isn't a phosphate or typical painted finish. Perhaps 'goop' just doesn't adequately describe it.
                            Mark
                            Kramden
                            • David L.
                              • July 31, 1980
                              • 3310
                              Mark,
                              The "goop" on my NOS 1971 blade reinforcement is hardly noticeable. You really have to look closely. I did not notice it until I took the photos.
                              Dave
