Distributor Date Code Band - NCRS Discussion Boards
    • 15643
    Re: Distributor Date Code Band
    Pat
    Looking good. Add a splash of color -- see Wayne's picture above for the location -- off the top of my head I don't know what color is appropriate for your application, but I know where to find out if no one beats me to it.
    Later 1970 distributors ahve a hole opposite the tach drive, but I don't see one in your pictures, so that is good.
    You do know that little dot on the distributor drive gear shown in image 3 should align with the rotor tip.
    • Mark D.
      1984-96 Team Leader
      • June 30, 1988
      • 2179
      Purple is the color you seek.
      Kramden
      • Wayne M.
        • March 1, 1980
        • 6414
        #18
        Originally posted by Patrick Nolan (48743)
        To build off of the conversation yesterday I am attaching a few pics of the distributor I am working on for my 68 L68. Cast into the upper housing are the numbers 231, no ID band is present so any thoughts on this dist being correct for the car is greatly welcomed as well as the knowledge you could pass my way as to what to look for to determine what is correct.
        Pat -- looked at my Feb 26th 1968 L71 distr. and see that it too has the "231" cast into the body. This has to be worth something pointing to your distributor being the original (as well as the no-hole mentioned by Terry M.).
        If you're touching up with black paint, note that the shaft flange that fits against the intake manifold is also black (but not on the underside).
        • Ron G.
          • December 1, 1984
          • 866
          #19
          A couple of things. First I would try to find an original as one aftermarket I.D. band was a little wider in width and the silver side was dull silver, not the bright silver that is usually seen on originals. As far as which side to be exposed, I have observed original Bowtie and Survivor cars with a 50/50. It does not make a difference which side is exposed, just as long as the info on the band is correct for the build date of the car.
          "SOLID LIFTERS MATTER"
          • Mark D.
            1984-96 Team Leader
            • June 30, 1988
            • 2179
            #20
            I agree on the color 50/50 thingy but, if you're going to pick one over the other, I know of a judge or two that will give you a point(s) deduction for the red on the outside, at least for the 68 thru 72 time frame. I'm not saying right or wrong, I'm just suggesting, if you're going to pick a side and you want to avoid a potential issue later, put the red on the inside. As always, do what you want since it's your car.
            Kramden
            • Patrick N.
              • March 10, 2008
              • 954
              #21
              Thanks, you guys rock!
              My engine assembly date is Feb 22 so I will try to find a 1111293 tag prior to that. I will shoot for silver out but might be swayed if all I can find is the red out.
              A daub of purple it is for my color splash.
              Terry-regarding the dot alignment- are you referring to the metal tang on the rotor?
              Thanks again.
              Pat
                • 15643
                #22
                Thanks again.
                Pat
                The rotor tip (the part the electricity travels through to the distributor post) and that dot on the side of the distributor drive gear should be in alignment. The rotor has one square peg and one round peg, so it can go on the top of the drive shaft only one way (unless one is related to Bubba). The distributor drive gear can be attached to the drive shaft two ways, but if the dot and rotor tip are in alignment you are (or should be) golden.
                Why does this matter? There have been several long threads on this subject, but I will see if I can make it brief.
                The location of the vacuum advance canister will interfere with the supports for the distributor ignition shield if the orientation of all these internal distributor parts is not right. There is a lot more to the story, but that is the Readers Digest version.
                I probably shouldn't mention it because I am not sure it is relevant, but FWIW: The original band on my 1970 LT1 has the red facing out. Since I bought the car new, I am sure it is the original.
                An NOS 1111491 that I bought from GMSPO in the โ€˜70s also has the red facing out.
                • Patrick N.
                  • March 10, 2008
                  • 954
                  #23
                  Thanks again Terry. I have the distributor "dry fit" together right now so when I disassemble to lube the parts I will align the dot and rotor tip.
                  Pat
                  • Don L.
                    • August 31, 2005
                    • 1006
                    #24
                    Mark's right. Don't ask me how I know ...
                    Don Lowe
                    NCRS #44382
                    Carolinas Chapter
                    • Mark D.
                      1984-96 Team Leader
                      • June 30, 1988
                      • 2179
                      #25
                      Repops are typically anodized on the red side which will draw negative attention in the form of a deduction.
                      Kramden
                      • Michael F.
                        • 745
                        #26
                        what do you mean by "correct configuration" also my late 70 LT-1 has red out also Terry.
                        Michael
                        70 Mulsanne Blue LT-1
                        03 Electron Blue Z06
                        • Wayne M.
                          • March 1, 1980
                          • 6414
                          #27
                          .... and here's a pic of an early 1971 LT-1 with red inside: 1112038__0__J__ 3; (3rd Sept 1970) Sorry it's a little fuzzy -- held a mirror so the red on the backside shows.
                          Two more in my collection: Red out: 1111267 (Z28 tach drive K66) 9_D_14 (14th April 1969).
                          Red in: 1112021 (Corvette) 0_B_23 (23rd Feb 1970, 350hp/350).
                          • Kenneth H.
                            • October 27, 2008
                            • 500
                            #28
                            My '70 LT1 1111491 distributor band, which I believe to be original, also has red side out.
