Hi Guys:
1965 327/300 HP auto w/air. Does anyone have a ball-park figure for how hot the exhaust manifolds get in normal driving? My dashboard water temp gauge was reading 135 degrees F after driving for 30 minutes so I shot the engine and radiator with a temperature gun. In the process, I also shot the exhaust manifolds from the top of the engine. Driver's side was 414 degrees F and passenger side was 449 degrees F. Is this normal, and shouldn't they be the same approximate temperature if the car is functioning properly? (it is stumbling heavily at idle)
Thanks in advance,
Frank O'Donnell
Troy, VA
Thanks in advance,
Frank O'Donnell
Troy, VA
