re Radio light ? - NCRS Discussion Boards
re Radio light ?
  • Wayne P.
    • January 23, 2008
    • 444
    re Radio light ?
    I had my Am FM radio repaired and bought a new speaker. Installed and sounds great. My question is their a light bulb inside the readio ?
    Doesn't seem to light up the main face. the bulb does for work on the outside for the gauges. thanks for any info. 1964
  • Stephen L.
    • May 31, 1984
    • 3157
    Re: re Radio light ?
    There is a light in the radio for the face. It is controlled by the off/on switch of the radio AND the dash lights. If the radio is off the light will be off even tho the dash lights are on. If it doesn't work this way, the light-switch portion of the radio off/on switch in the radio is possibly bad or the bulb has failed.
      Wayne -
      The radio dial light only works if the dash lights are on (headlight switch knob pulled out to parking or headlghts position) and the radio is turned on. Radio on & dash lights off = no light. Radio off & dash lights on = no light.
      • Wayne P.
        • January 23, 2008
        • 444
        Thanks. I will take the radio out and look for the bulb . Cheers
        • Dan B.
          • July 13, 2011
          • 545
          Wayne, if you remove the left (drivers) side panel, you will be able to access the radio bulb to check/replace it. No need to remove the radio. Dan
          • Wayne P.
            • January 23, 2008
            • 444
            Dan sorry I seem to be a little dense. I see a bulb that clips on the outside of radio on the drivers side . working. is their another access to the inside of radio
            • Stephen L.
              • May 31, 1984
              • 3157
              Here is a photo showing the light mounted correctly on the left side of the radio cover.
              • Wayne P.
                • January 23, 2008
                • 444
                That's my issue located outside not inside. thanks. Easy fix.
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  And that's part of the problem with 1964 radios. The white wire shown in Stephen's pic is the routing for the '65-7 radios. the '64 has the wire routed inside the metal side panel, exiting only where the clip on the side is located. This makes it difficult to slide the clip/lamp assembly off the tab on the side cover.
