engine code help - NCRS Discussion Boards
engine code help
  • Richard C.
    • July 31, 2001
    • 144
    engine code help
    Good morning, Would somebody help me w this engine code please? cla192120 thanks richard
  • Lawrence M.
    • February 1, 1995
    • 404
    Re: engine code help
    Richard, I'll try and help. According to the "Lime Book" if it is from a Corvette, which the 19000 series may indicate, it would be a 350 ci with automatic trans from 73,74 or 77.
    Larry
    2002 Z51 Convertible
    1969 L46 Convertible
    • Michael W.
      • April 1, 1997
      • 4290
      Richard,
      Is that the exact format of the stamping, with nothing else on the pad? Not typical of a factory installed engine if so.
      • Ray K.
        • July 31, 1985
        • 375
        Richard
        According to my Chev P & A catalog the " CLA " designation was used for the 1973 - 74 Corvette and also the 1977.
        The '73 - 74 references a --- 350 CID engine with T. H. 400 trans ( Base engine L48 )
        The 1977 reference is ---- 350 CID engine ( Neither auto or manual trans identified )
        Ray
          As Mike noted, that's not a typical pad stamp. Please post exactly what's stamped on the entire pad, or a photo.
          • Richard C.
            • July 31, 2001
            • 144
            these are the only numbers on the pad. thank you for the help!
              Richard -
              The "CLA" suffix was used on '73-'74 and '77 Corvette base engines with THM-400, and several later passenger car applications; however, the format you noted was never used in production - the "CLA" suffix would have been preceded by a "V"with four digits for the month and day, and there would be a separately-stamped 9-digit assembly plant VIN derivative. What you have is most likely a rebuilder's I.D. code - a close-up photo would confirm that.
