Attached (hopefully) are some pictures of the door gaps on my 66 convertible. The archives has lots of information about adjusting the door within the door opening to get the gaps even. I have a different issue.
The door gaps on the driver side are tight. The door gaps on the passenger side are wide. I might be able to adjust the pass side to 1/4" gaps front and rear.
It looks to me like the rear section is "askew" from the centerline, ie, the rear is bent to the left of center. Since the rear section is attached solid it looks to me like no amount of adjustment at the body mounts is going to reduce the door opening on the passenger side and increase the door opening on the driver side. Am I correct? Is there any adjustment that will reduce the width of the door opening?
FYI This summer the body was professionally removed from the frame to replace a leaking fuel line. At that time #4 rear body mounts were repaired because the holes we enlarged due to rust caused by water trapped in the rubber "donut's". The mounts were not moved, just a plate added to provide correct size holes.
The door gaps were not great before the body was lifted but they seem to be more noticable now.
In summation is there a way to adjust the rear section to reduce the total door opening on the passenger side?
Randy
Randy
