As you know, the 66 A/C hood supports were moved to the left side and a crude hole was cut into the frame to allow the support bracket to be attached with Pop Rivets. This set up often started to deteriorate after a while, as mine did. So I ground out the rail and reinforced it from the inside , replaced it, and glassed over everything . Including the crudely ground out hole in order to start over again fresh. Fast forward 10 years later , and I now can not find the pictures I took of it before I did all this .
So, My question are these : Was the hole cut and the bracket installed before or after blackout?
The difference would be a raw glass appearance at the hole, and unpainted rivets if installed afterwards, or all blacked out if installed before hand .
Anyone have any pictures of the hole and set up ? As that would help as well .
Jim
Jim
