63 front hood wedges - NCRS Discussion Boards
  • Charles K.
    • May 31, 2000
    • 2
    Would someone please post detailed photos of LEFT & RIGHT FRONT HOOD WEDGES,on hood,NOT BODY! That show proximity of wedge & rivet heads relative to 1 inch in hood frame on drivers side.
    Thanks!!
  • Gary F.
    • August 29, 2010
    • 248
    Re: 63 front hood wedges
    I have more pics of this. My car had front & rear wedges.
    • Harry S.
      • July 31, 2002
      • 5344
      Charles, what are you trying to accomplish? If you believe your hood is original to the car, the bolt holes should already be there. Also, some 63 cars had no wedges, some had two and some had four. Coupes were different than convertibles. Check the JG.
      • Andy C.
        • May 31, 1987
        • 71
        Charles; Early 63 hoods had NO provisions for any hood blocks. Then the hood was changed to have the 4 hood blocks. If your hood does not have the bolt plates inside the hood then you have an early 63 hood...
