slipping out of 4th gear - NCRS Discussion Boards
  • Robert S.
    • December 11, 2011
    • 3
    When I let off the gas my transmission slips out of 4th. 1962 340hp .
  • Carl N.
    • April 30, 1984
    • 592
    Re: slipping out of 4th gear
    sounds like time to R&R as the 3/4 syncronizer is worn out
    might as well r&r trans with all new syncronizers, seals and bearings not hard to do
    don't forget throwout bearing and pilot bushing in flywheel.
    • Terry D.
      • May 31, 1987
      • 2698
      Robert
      How about a little more info? Have you made any chamges to the driveline lately? Does it shift ok? How long had it been working ok? Is the linkage adjusted correctly?
      • Joe R.
        • July 31, 1976
        • 4552
        Gonna have to agree with Carl based on the limited information. You need at least a "dove tailed slider" and synchro rings providing that fourth gear teeth are not worn completely out.
        Best approach would be to have a good trans expert inspect the trans on his bench. The only way you are gonna know for sure.
        JR
