Is there any difference between a 1960 and 1962 or later distributor other than it appears to have replaceable bushings. Also is the main reason that there are so many distributor numbers in that they are the same except for the vacuum unit and the spring weights. I know that they will "fit" but are threre any other concerns in matching the distributor to the engine.
Phil
Phil
