This seems very odd to me, but when I check my battery voltage with my digital VOM, (Car Parked) Positive lead on the + battery post and Ground lead of the meter to engine block or frame etc I get a reading of 12.76V.
When I move the negative lead of the VOM to the Aluminum Radiator I get a higher reading of 13.3V. Anywhere else other than the radiator for ground shows the same 12.76V.
Is this normal?? Why does the voltage look higher when grounding the VOM negative probe to the aluminum radiator?? (When the car is not used the battery is always disconnected)
Makes no sense - or does it?
