56 Engine Value - NCRS Discussion Boards
56 Engine Value
  • Cathy S.
    • August 31, 2003
    • 293
    56 Engine Value
    I have the opportunity to obtain a correctly dated, restored 56 engine for my car. Rebuilt/balanced carb to pan, no water pump, exhaust manifolds, distributor nor fuel pump (i.e., long block with carb). Whats this worth?
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 56 Engine Value
    Much of the "weight" and "value" of this engine will revolve around whether or not it is an "early" (RH dipstick to side of pan,
    exhaust manifolds, etc., etc.) or the later (and generally more available) engines. You need to provide more information.
    • Cathy S.
      • August 31, 2003
      • 293
      Re: 56 Engine Value
      No exhaust manifolds yes rh dipstick
      • Cathy S.
        • August 31, 2003
        • 293
        Re: 56 Engine Value
        No opinions on worth?
        • Philip P.
          • February 28, 2011
          • 558
          Re: 56 Engine Value
          Cathy, I'll take a shot I am getting my 283 rebuilt it is the original engine to my car. The rebuild machine work, etc will be about $3,000. Seeing that mine is serial numbered to the car it really cannot be replaced but I would think a dated block heads etc would be worth $1000 minimum, mine is a base engine also so that makes a difference, compared to a FI engine. I do not know the rarity of a correct 265 block but it may be harder to find than mine, that being said I would guess somewhere around the $4,000 to $6,000 may be in the ball park. I may be off on this but that is about what I will have in mine when all is said and done.
          Hope this give you some idea
          Phil
          • Cathy S.
            • August 31, 2003
            • 293
            Re: 56 Engine Value
            It does help thank you Phil
            • Gary C.
              Administrator
              • October 1, 1982
              • 17935
              Re: 56 Engine Value
              Cathy,
              Make sure it's a Flint block and heads.
              Gary
              NCRS Texas Chapter
              https://www.ncrstexas.org/
