CE Blocks - NCRS Discussion Boards
CE Blocks
  • Michael J.
    • January 27, 2009
    • 7166
    CE Blocks
    I am researching some issues about CE blocks, were they ever stamped and if so, what were they stamped with? Thanks.
  • Patrick B.
    • August 31, 1985
    • 2010
    Re: CE Blocks
    Other than the CE number stamping, what stamping are you talking about?
    • Tom L.
      • October 17, 2006
      • 1439
      Re: CE Blocks
      I have a CE block in my '72. I believe it is a warranty replacement because the date on the block is within 8 or 9 months of the build date for the car and the heads (cast on the same day), intake, and exhaust manifolds pre-date the build date. On the stamp pad the engine build date and engine code are crudely stamped in along with the CE number. The head covers about half of it. I think that perhaps the dealer may have stamped that into the block. I hae a picture but not here, I can get it if it will help answer your questions.
      • Kenneth B.
        • August 31, 1984
        • 2091
        Re: CE Blocks
        Check the old threads on CE blocks on here. John Z ansewered most of of the questions & miscoseptions about CE blocks.
        KEN
        • Mike E.
          • February 28, 1975
          • 5141
          Re: CE Blocks
          The CE engine would have arrived at the dealership with the CE sequential number--the dealership would have stamped anything additional.
          • Michael J.
            • January 27, 2009
            • 7166
            Re: CE Blocks
            OK, thanks. I was just wondering if they always had CE on them and if the dealers ever stamped VIN derivatives.
            • Tom L.
              • October 17, 2006
              • 1439
              Re: CE Blocks
              The ce and engine code is all I can see. As I said, the engine code is about 50% covered by the head and the CE completely exposed. Who knows, maybe the vin got stamped and is also covered by the head. Don't think I'll pull it to find out though.
              • Patrick B.
                • August 31, 1985
                • 2010
                Re: CE Blocks
                I bought a 427 car in Texas that had a CE numbered block, and a '66 Corvette VIN derivative crudely hand stamped on the pad also. I don't know if a dealer stamped it or if it was just a Bubba stamping to give it "matching numbers". I still have the block and can take a picture next week if that would be helpful. I also bought a 350 car in Maryland that had a fitted block definitely installed by a dealer under warrantee with a CE number, but the dealer did not add any stampings.
                • Tom D.
                  • September 30, 1981
                  • 2145
                  Re: CE Blocks
                  I have seen a 427 block with only the "T", four numbers for the date, followed by "IL", same as you would expect in a 390 HP Corvette. However, there was no VIN. It was cast in late '66 or early '67.
                  https://MichiganNCRS.org
                  Michigan Chapter
                  Tom Dingman
                  • Jim T.
                    • March 1, 1993
                    • 5351
                    Re: CE Blocks
                    My 1970 Corvette bought new from the showroom floor of the dealership in August has a CE engine block. All that is stamped on the engine pad is CE0A4753 and about two spaces away not in line with the initial stamping is a 8 that is not a perfect stamping.
                    It is a 3970010 block with D260 casting date. My original factory installed 350/300 failed minutes after leaving the dealership due to a oil circulation problem. The CE engine block was not painted before installation and is still unpainted.
                    • Patrick B.
                      • August 31, 1985
                      • 2010
                      Re: CE Blocks
                      Tom:
                      An engine with the Tonawanda stamp on the pad for a Corvette but no VIN would have been sold as a complete over-the-counter engine rather than installed in a car.
                      • Tom D.
                        • 2145
                        Re: CE Blocks
                        Patrick: Thanks - That's a good explanation.
                        Michigan Chapter
                        Tom Dingman
                        • Tom L.
                          • October 17, 2006
                          • 1439
                          Re: CE Blocks
                          IMG_2029.jpgI didn't pull the head to look at the stamp but unfortunately I had to due to other problems. I took a pic of the stamp that was half under the head. Not sure if anyone is interested but I figured I'd throw it up anyway.
                          • Lyndon S.
                            • April 30, 1988
                            • 1027
                            • Michael W.
                              • April 1, 1997
                              • 4290
                              Re: CE Blocks
                              I value the post from an educational and historical point of view, nothing to do with judging.
