Spring liner issue - NCRS Discussion Boards
Spring liner issue
  • Tom L.
    • October 17, 2006
    • 1439
    Spring liner issue
    My brother-in-law recntly bought a spring liner kit for his '64 from Paragon, the same part number I bought last winter for my '72. They shoud be the same, right?? When we went to put the spring together the liners were too narrow. Anyone have a recent experience with these??
  • Paul O.
    • August 31, 1990
    • 1716
    Re: Spring liner issue
    Lynn
    Measure the spring it should be 2 1/4 inches if the spring is 2 1/2 it a later replacement spring with a later differential cover.
    Paul 18046
    • Tom L.
      • October 17, 2006
      • 1439
      He measured his, I measured my original (that was cracked) and the used original I bought. All the same. Not sure why there's adifference in the liners.
      • Don H.
        Moderator
        • June 16, 2009
        • 2254
        Lynn,
        did you put it together and tighten up the bolt, using C Clamps to squeeze the spring tight? I just restored an original spring for my 65, and bought the Paragon liner set about one month ago. The liners looked to be the same overall width as the leaves themselves, ie. 2 1/4" meaning that the space between the liner sides looks narrower than the leaves. However, when I assembled the spring and tightened it together, before hanging it under the car, the leaves apparently made the liners stretch slightly wider and all the pieces nested tightly together, as you want it to. Came out fine.
        • Doug L.
          • March 14, 2010
          • 442
          I can't tell you why I think this but I believe the 9-leaf spring was basically the same from 1963 to 1977. If correct it seems that the liners should be the same too. I bought 2 sets of liners from LIC, one for my incorrect 10-leaf service replacement spring and another for a correct 9-leaf spring that I bought later. The springs and leafs were identical.
          Doug
          • Tom L.
            • October 17, 2006
            • 1439
            No we did not put it together, the width of the liner and spring aren't even close. This is not my spring but last winter I did my spring with liners from Paragon, same part number, and they fit just fine. I guess that's why I'm concerned and didn't move further. I don't have the inside width of the liner but I'll get it and post it. Perhaps they changed the design and want the liners squeezed out???
            • Jeff S.
              • July 31, 1984
              • 384
              Here's a couple pics of liners with correct fit ('63 9-leaf spring). I believe I got them from Keen Parts, but not certain.
