Tri-Power "T-fitting" question. - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    I have the original plastic T-connector and a new one that came with my hose kit. The "center" fitting on the original is a larger diameter than the two fittings on each end. The repo has all fittings the same diameter. The replacement hose is impossible to fit onto the original larger dia. fitting. I must be missing something obvious, were all the hoses the same dia. or should I have a larger dia. hose for the center fitting?
    Best,
    Pat
  • John C.
    • January 1, 2005
    • 616
    Re: Tri-Power "T-fitting" question.
    Pat
    What are the diameter of the ports? All the T-connectors I have seen for the tri-power hoses are the same diameter on all three ports.
    There are some smaller diameter hoses used in the AC and headlight control systems. The connector could have come from one of these systems.
    John
    • Patrick N.
      • March 10, 2008
      • 954
      Bingo-thanks John. I just dug up my parts bag with the lights vacuum fittings and found the tri-power fitting there. Been so long that I completely forgot about that, I knew it had to be something obvious.
      Thanks again,
      Pat
