New Glass Polishing Kit Created - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    Hi All,
    I've been trading emails with the president of the Glass Guru company makers of the scratch removal kit for glass. They have a kit that is $1370 and it's geared toward pros doing many jobs. I asked if he could create a "hobbyist" kit for us doing single windshield repairs. They have created 3" and 6" starter kits.
    The info is below. The 3" kit is $262 and the 6" kit is $357.
    Don
    Don-
    Hope you had a good New Year's weekend and things are working out on the windshield. *I got a call from another guy in your association this morning who I'm assuming you sent over so thanks again. *We took your suggestion and added a new page (http://scratchremovalstore.com/scrat...ategory=10)*to our store with *3" and 6" starter kits that we now have available. *
    All the best in 2012,
    Dan Frey
    Founder/CEO
    The Glass Guru
    (916)786-4898
    Fast, clean glass repair, replacement & restoration across the US & Canada. Free estimates, honest pricing, and local pros you can trust.
    Each 3" Starter Kit Contains:
    3" Backer Pad & Interface Pads
    Initial Supply of Grinding & Polishing Pads (52 total pads!)
    Ultra-Premium Quality Polishing Compound
    Wide-mouth Sprayers for Polshing Compound & Cleaning Solution
    Metal Rasp
    Protective Dust Mask
    Detailed Instructions
    Unlimited Technical Support
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: New Glass Polishing Kit Created
    IMHO.
    If windshield glass is not reletively flat it will produce distortions.
    Therefore by removing a localized scratch a low spot is created in the windshield and distortion will be present.
    • Gary B.
      • February 1, 1997
      • 7070
      Don,
      Does the 3" and 6" spec refer to the diameter of the abrasive pads?
      I think it's great that you took the initiative to ask for these starter kits. This should make the system affordable to many more hobby-class people.
      Gary
        • 15632
        Don,
        Thank you for taking the initiative and thanks too to Dan for being responsive to us hobbyists.
        • Terry D.
          • May 31, 1987
          • 2697
          I agree with Bruce, be very careful where the scratch is. If it is in your line of sight, you are going to be very disappointed with the distortion. Think of it as filling in a low spot when doing body work, if you build it back up and level it off no one will know, if you don't it will wave to you forever. Just my old two cents.
          • Don W.
            • 492
            Originally posted by Gary Beaupre (28818)
            Don,
            Gary
            Hi Gary...Yes, the 3" and 6" are the pad diameters. They also have 8" pads...Don
            • Don W.
              • 492
              I pinged the owner on how to deal with any glass distortion issues. Here's the response. FYI...Don
              Anytime you grind down the surface of glass you can leave a low spot which causes distortion. *When simply polishing glass this will rarely occur as the polish removes such microscopic layers of glass it would take an extreme amount of time remove enough to cause noticable distortion. *When using more aggressive grinding pads, its important to maintain an even grind and to feather the area out significantly to minimize the distorted effect.
              Dan Frey
              Founder/CEO
              The Glass Guru
              • Rick M.
                • June 30, 1995
                • 74
                Has anyone used this system?
                • Don W.
                  • 492
                  Yes, I saw posts in the archive where this system was used
                  • Don W.
                    • 492
                    Here's an older post discussing the products
                    https://www.forums.ncrs.org/showthre...lass+polishing
