Removing a Valve Cover Decal - 1960 Car - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1343
    For some reason, I applied a "230" decal on both stamped steel valve covers. Of course, I now know that is incorrect. Is there anyway to remove the decal without stripping the paint and decal and starting over?
  • Thomas H.
    • August 31, 2005
    • 1068
    Re: Removing a Valve Cover Decal - 1960 Car
    Joe,
    I assume you used water to put the decal on. How about trying to soak it, maybe with a sponge or rag, to soften it up and then rub it off?
    I need to remove mine as I don't like the way I put it on. I was planning on trying this method. (I bought two decals knowing that the chances were pretty good I'd mess the first one up)
    Tom
    2007 Z06, Lemans Blue
    • Joe M.
      • April 30, 1990
      • 1343
      It is the water release type decal. I don't want to remove the valve cover so I am going to soak a rag in water and cover the rag with plastic so it stays wet for several hours and see if I get lucky. Will keep you posted.
      • Edward S.
        • December 1, 1986
        • 514
        I might try to do what I also do with stickers, decals, etc - I use a heat gun and warm one corner heat and peal off. Just go slowly. Good luck
