Inspired by the unusually good weather in the Northeast, I decided to give another try to installing the Hardtop on my 59 and see if I can finally figure out why it does not fit well around the door glass windows.
A little history, the car was a soft top only car, bought the top in the 80's and had it painted along with the car but never tried to install it. It has it's original windows and weatherstriping in place. It's been in storage (standing up on the header and rear window leaning evenly against the wall).
THE PROBLEM: As the photo's show, my biggest problem is the door window gap on the right side is uneven. Also, I can't get the left hold down bolt hole to line up (top is 1/4 inch too far back) which coincidentally is the gap (uniform) at the left rear window. I can drive with it the way it is with 2 bolts in the rear and the front latched down, but it does not look right.
NOTE GAPS AT TOP AND SIDE
LEFT HOLD DOWN OFF 1/4" REARWARD
LEFT WINDOW GAP SAME 1/4" TOO WIDE (AS MOUNTING HOLE ABOVE)
FIT AROUND THE DECKLID IS PRETTY GOOD
I re did the Windshield when I painted the car but did not specifically fit it to the Hard top. It has all the correct gaskets in place and ONE RUBBER SHIM on each side of the Windshield posts. The Windshield fits well as does the Soft Top and the door posts. I adjusted the windows as much as possible and the door gaps, and rear deck lid alignment are as good as possible also. I don't use the Top enough to justify sending it out for a complete restoration, but I would like to make it fit and function better if there are some things I could do myself. What do you think???
Dan
