I purchased a restored voltage regulator for my 66. It is part number and date correct. It was to replace a later after market electronic (if that is the correct term) voltage regulator.
I am trying to figure out if it is working correctly. I am using a tester/monitor (pictured below).
For the electronic VR I get charging voltage of 14.2-14.4 volts at 1500/2000/2500 RPMs, doesn't change much after 1500. That is well within the specs in the 66 Chassis Service Manual (13.5 to 15.2). Also at constant RPM, the Battery meter is stable at 0. If I switch on the headlights the batt meter kicks to negative a slight amount, but quickly moves back to zero. If I turn on the turn signal the meter kicks to negative and bounces in conjunction with the turn signal but not much.
For the correct VR I get charging voltage of 13.6 volts using the tester/monitor, which is still within specs. However, the battery meter is a lot more active. At idle, the batt meter bounces around a little. If I switch on the headlights, the battery meter starts bouncing around, to negative back positive and keeps bouncing around until I switch the lights off.
Is this normal for an original type voltage regulator?
