1972 Heater Core - Which one to purchase - NCRS Discussion Boards
  • Jeff Y.
    • March 10, 2008
    • 73
    I need to replace my heater core and don't know which one to purchase. I'm seeing brands from Spectra Premium, Four Seasons, Ready-Aire, Vista Pro. Are they all the same? I really don't want to do this job twice by picking a substandard one and having to do it again in a year.
  • Lyndon S.
    • April 30, 1988
    • 1027
    • Paul L.
      • November 1, 2002
      • 1414
      Re: 1972 Heater Core - Which one to purchase
      This was my choice for A/C applications. For my 1974 in 2008. I don't know if they are still available.
      (thumbnail)
      • Jeff Y.
        • March 10, 2008
        • 73
        Paul, I would like the brother to that one for a non-AC car. However, does not seem that you can get an AC Delco core any more.
        • Paul L.
          • November 1, 2002
          • 1414
          Strange. That was only three years ago here in Canada that I did that job. I "think" Joe Lucia gave me that number at the time and it worked for my local AC Delco dealer. Other members may have suggestions for a non-A/C car. I can't give you one. Sorry!
          • Larry M.
            • December 1, 1986
            • 541
            I purchased one for our '72 from a local auto radiator shop in 1986. Generic brand, IIRC. Still working fine.
            • Rich C.
              • January 1, 1994
              • 383
              If your finicky, N.O.S. ones are still out there, found one last year for my future restoration!
              '73 LS-4 454 owned 21 3/4 years
              • Jeff Y.
                • March 10, 2008
                • 73
                Does anyone have the AC Delco part number for the non-AC heater core?
                • Rich C.
                  • January 1, 1994
                  • 383
                  #3014900 is the # listed in my '73 parts book. I'll check my '82 parts book if you want to see if # changed. I've found on many parts the part # is superseded several times 'till they just discontinue them altogether! Your chevy dealer should be able to access all that info and do a dealer search of all #'s! ( at least mine does!)
                  • Chuck G.
                    • May 31, 1982
                    • 2039
                    Whichever one you buy, it would be a wise idea to have it pressure tested at your local radiator shop before you install it.
                    Chuck
                    • Dick W.
                      • 10483
                      Four Seasons parts are usually very high quality, come to think of it, they make most of the aftermarket A/C parts for the older cars.
                      Dick Whittington
                        • 43290
                        Jeff------
                        GM #19131997 is what you seek. I believe it's GM-discontinued but there should be some still around. Also, as Dick has pointed out, Four Seasons heater/AC parts are high quality. Very likely, they are the manufacturing source for the Delco piece.
                        • Paul Y.
                          • September 30, 1982
                          • 570
                          I have found that the radiator shops will replace the core and put your tanks back on with the date on them. Best of both worlds-new core and dated tank that matches your vehicle. I'm sure Four Seasons has a supply of them. Just ask the shop before you commit with your old core.
                          It's a good life!
                          • Dick W.
                            • 10483
                            Paul, from my experience while owning a radiator repair shop in another life, you are way ahead of the game by replacing the core assembly. Brass, over a period of time, will work harden from vibration.
                            Dick Whittington
                            • Paul Y.
                              • 570
                              Thanks Dick, that makes a lot of sense and I will heed that advice on the one I am replacing in the near future.
                              It's a good life!
