'67 Antenna bezel Part # - NCRS Discussion Boards
  • Daniel S.
    • January 14, 2011
    • 309
    Hi Guys,
    Can someone supply the correct part # for a 1967 Corvette Antenna mounting bezel? Thanks.
    Dan
    Re: '67 Antenna bezel Part #
    Originally posted by Daniel Schutzbank (52694)
    Hi Guys,
    Dan
    Dan -
    The die-cast chrome bezel with the alignment pin on it is GM#3903427. It's shown in your Assembly Manual, section U69,. sheet B1, item #3.
    • Scott S.
      • September 11, 2009
      • 1961
      Dan -
      John,
      Do you know if the part number (GM 3903427) is on the part itself, or what the difference is between GM 3903427 antenna bezel and the GM 3921439 bezel (supposedly for 1968-69 and '73)?
      LIC offers the same antenna bezel for 1963-1968. Same for Corvette Central. Paragon also offers one antenna bezel for 1963-68, and actually calls it GM 3921439.
        • 43290
        Originally posted by Scott Smith (50839)
        John,
        Scott------
        The 3921439 might work. However, the GM #3903427 was discontinued without supercession in November, 1978. So, that implies that GM did not consider the 3921439 to be an acceptable replacement. The 3921439 was discontinued without supercession in October, 1991.
        • Scott S.
          • 1961
          Scott------
          Thanks for checking Joe,
          I will keep looking then for a 3903427.
