Big Block Hot Cam Vacuam Advance CAn - NCRS Discussion Boards
  • Anthony P.
    • October 26, 2011
    • 199
    Working on a 69 big block with a Big Cam (low vacuam) does anyone have a recommendation for a distributor vacuam chamber that with work beter then a stock one?? Engine has about 8-10 inches at Idle now
    Thanks in advance
    Tony
  • William C.
    • May 31, 1975
    • 6037
    Re: Big Block Hot Cam Vacuam Advance CAn
    Thanks in advance
    Tony
    Per Delco test data, part number 1116089 starts at 4-6 inches and all in at 7.5 inches, also 1116120 at the same specs, 1116125, stsrts 4-5 in at 10.0-12.5, 1116158 start 5-7, all in at 7.5-10, 1116170 start at 2.5 all in at 7-9, look like your best choices.
    Bill Clupper #618
    • Anthony P.
      • October 26, 2011
      • 199
      Thanks It is just what I was Looking for!!
      Thanks Again
        • 15706
        You want the VAC stamped "B28". It is available in a number of different brands, including Delco, but all are the exact same part made by Standard Motor Products. Lots of discussion in the archives.Duke
        • Anthony P.
          • October 26, 2011
          • 199
          Thanks Duke
          Do you know the approx vacuam points on this (Inches) of vacuam?
          Tony
            • 15706
            Start @ 4", 16 (at crankshaft) @ 8" are the nominal specs.
            • Anthony P.
              • October 26, 2011
              • 199
              Ok that sound great
              Tony
