66 frame marks - NCRS Discussion Boards
66 frame marks
  • Matt L.
    • February 23, 2010
    • 337
    66 frame marks
    i found some frame chalk marks on the front driver's side frame under the radiator support that have a white mark and an orange shade mark in between the white marks. i am familar with the body shim markings being white but what would these be?
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 66 frame marks
    Shims were placed at this location as well. Unless someone has changed the shim count, this should be the number of shims you'll find at this location.
    • Matt L.
      • February 23, 2010
      • 337
      Re: 66 frame marks
      i understand the shim count relating to the chalk marks. but i dont recognize the orange/yellowish mark in between the white marks. i thought all chalk marks were the same white color. this is an ao smith body. maybe they are different from st louis ?
      • Rich P.
        • January 12, 2009
        • 1361
        Re: 66 frame marks
        I have seen orange to signify 5 shims so if you have 2 white and 1 orange you shouold have 7 shims welded to the fron frame.
        Rich
          Re: 66 frame marks
          Matt -
          Frame shim marks were measured and applied on the Frame Line at St. Louis, several hours before the body met the frame; didn't matter which plant the body came from.
          • Mike B.
            • July 31, 1994
            • 843
            Re: 66 frame marks
            Hi Matt,
            I agree with Rich. I've always been told an orange crayon strike represents 5 shims. When I removed the front bumper braces way back when off my A.O. Smith '65 #14xxx convertible I found an orange and 2 or 3 white crayon strikes there. It all jived with the shim count.
            Mike
            • Ronald L.
              • October 18, 2009
              • 3248
              Re: 66 frame marks
              Nice RSC's right next to those frame shims
