Installing Diff Crossmember Cushion - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    Okay, thanks to this board I got my crossmember cushions off now what's the best way to install the new ones? I tried a huge C clamp and a huge sledge hammer and I've got it almost all the way in but it's does not want to go further - at least not easily - so I thought it best to ask before I screw something up!
    Jack
    Jack Ottofaro
    • 43263
    Re: Installing Diff Crossmember Cushion
    Jack
    Jack-----
    1) Make sure the cushion orifices in the crossmember are 100% rust free;
    2) Lubricate the orifices with a very light film of chassis grease;
    3) PRESS the cushions into the crossmember using an appropriate press plate and a HYDRAULIC PRESS.
      Jack -
      Like this...
      • Jack O.
        • July 31, 1996
        • 527
        Thanks Joe and John. The second one I did similar to the picture here - used something to go over the entire cushion and pressed it in. However the first one I let the press go down into the cup where the bolt goes and I noticed it stretched the rubber out quite a bit (that's why I did the second differently). Could I have damaged it and should I be concerned that it could fail prematurely? The rubber didn't rip or tear though.
        Jack
        Jack Ottofaro
          • 43263
          Jack
          Jack------
          I doubt that you damaged it but it's not beyond the realm of possibility.
          • Wayne M.
            • March 1, 1980
            • 6414
            Jack -- here's how the General said to do it. This was back when the early cushions with fewer tabs were experiencing "pull-out" and needed replacement with the newer design.
            y
