64 Fan Clutch - NCRS Discussion Boards
64 Fan Clutch
  • Larry M.
    • March 1, 2002
    • 62
    64 Fan Clutch
    I have a 64 327-365hp and need a new fan clutch. Where is a good place to get one? Car was built in Jan. 1964. Thanks......
    • 43281
    Re: 64 Fan Clutch
    Larry------
    If you are talking about an EXACT ORIGINAL clutch, you're going to have to find a core (if the one you have now is not an original unit) and have it rebuilt by one of the few rebuilders doing this sort of work. By the time all is said-and-done you're probably going to have $750-$1,000 in it.
    A much better plan is to obtain a NEW GM #3916141. It's close to the original in configuration, will perform perfectly, and will be NEW. If you drive the car, this is the absolutely best option.
    • Dan K.
      Infrequent User
      • May 31, 2007
      • 7
      Re: 64 Fan Clutch
      there are adds in the driveline under services call dan before you make up your mind on what direction to go
