RE: 1969 rear console - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    I am thinking about restoring a rear console. looking for a way of removing the old finish. thanks
  • Joseph K.
    • August 26, 2008
    • 407
    Re: 1969 rear console
    Jerry,
    Not sure what the rear console your referring to. If it is the area behind the E-brake I believe it is a painted surface. Mine a is black and it is not painted because my interior is black and it is made of black plastic. If your interior is a different color it would need to painted to match.
    • Jim M.
      • February 23, 2009
      • 233
      Are you sure it's not covered with vinyl?
        • 43219
        Jerry-----
        If you're talking about the EMERGENCY BRAKE CONSOLE, this piece was made of an ivory-colored plastic material and painted the appropriate interior color (including black).
        Anything you use to try to remove existing paint is going to do a lot more harm than good. I would not attempt it. You can get excellent results by just cleaning it THOROUGHLY and repainting with SEM interior paint. It will appear like new.
        • Joseph K.
          • August 26, 2008
          • 407
          Jerry-----
          Joe,
          The one on my 69 was black all the way through. the reason I know this is that it was broken and the black color was all the way through the plastic. I replaced it with one from Al K.
          • Mike F.
            • April 25, 2011
            • 668
            I just bought an emergency brake console for my 70 from Al K.
            The first one I received was black plastic covered in black vinyl. It looked good, but the vinyl is not accurate for a 70.
            The second one I received was black plastic and looked like crap. You could see the circle/rings on the exterior that corresponded with where the screws/studs attached on the inside.
            I then spoke with Elliot K.(?) who informed me that all parking brake consols are being made or are coming from one company in Taiwan/China.
            Al K. adds the vinyl to make it look better.
            True, false? I don't know, just my experience.
              • 43219
              Originally posted by Joseph Koehler (49378)
              Joe,
              Joseph----
              Are you sure it's an ORIGINAL console? All the ones I've seen from 1969 are an ivory-colored plastic which is painted interior color. Some of the later GM SERVICE consoles were a light gray plastic. I've never seen a GM console which was black plastic.
                • 43219
                Mike-----
                Vinyl-covered emergency brake console is not correct for ANY 69-76.
                  • 6941
                  Mike, a few years ago I purchaced one from corvette america and was a perfect match. they can be brought with the correct color. but found that after 40+ years the other colors don't quite match.
                  • Jerry B.
                    • August 31, 1994
                    • 416
                    Mine was also painted at the factory. In fact, there was alot of overstray on the underneath.
