Wiring harness - NCRS Discussion Boards
Wiring harness
  • Thomas H.
    • August 31, 2005
    • 1068
    Re: Wiring harness
    Originally posted by Lyndon Sharpton (12791)
    Anyone have a idea what these two wires connect to? I am almost sure the one marked on top goes on the switch. But the other ones I don’t know what they go to
    I have a NOS switch #3990843 it looks like it has two prongs or maybe 3. Could this part be where the other two wires connect?
    Lyndon,
    I was able to zoom in on the picture posted and the two connectors, the brown wire one and the green wire one, both go to the rear relay. The other connector you have loose under the existing relay should go to the front, or delay, relay.
    Jack Humphrey wrote a great article for the restorer on the 71 CEC system. Check out the Spring 2009 issue for all you'll probably ever need to know on the 71 CEC system.
    Tom
    2007 Z06, Lemans Blue
    • Lyndon S.
      • April 30, 1988
      • 1027
      Re: Wiring harness
      Then what color wire goes to the solenoid on the carburetor any clue?
      Also anyone know what part numbers should be on both switches on the firewall be a 3990843/3990842 respectively ?
      • Thomas H.
        • August 31, 2005
        • 1068
        #18
        Re: Wiring harness
        Yes, I'm ashamed to admit that I don't know or have the block casting date written down. The heads are July 70 and the intake is June 70. The transmission (4sp) is Aug 70. The earliest dated part that I have notes on is the pass side door glass and that is March of 70. All other glass id either June or July. The differential gears are Aug of 70.
        I suppose I was one of the lucky ones that got a 4 bolt block. I surprised to see that when I took the engine apart.
        I made a pretty comprehensive list of the date codes of the parts on my 60 when I was going through it last year. I need to do the same with the 71 when I wake it up in the spring.
        Tom
        • Thomas H.
          • August 31, 2005
          • 1068
          #19
          Re: Wiring harness
          The solenoid wires are blue and tan (maybe black?)
