68 Harrison Radiator Value?? - NCRS Discussion Boards
  • Christopher A.
    • February 13, 2009
    • 167
    Im curious to the value of an original harrison aluminum radiator in great condition. This particular radiator is for a 68 small block. Do these original radiators have any value? I did a search on the internet, but all i came up with were damaged originals for cheap or new correct reproductions for sale.
    • 6948
    Re: 68 Harrison Radiator Value??
    Chris, unless the radiator was a early take out. a 40+ year radiator for someone putting it in there car for a daily driver might be a gamble. for someone looking to Top Flite or Duntov a car it may work.
    As far as value, Put it on E/bay and put a figue you think it worth, Shipping will be expensive, Unless someone local is the winning bidder.
    • Christopher A.
      • February 13, 2009
      • 167
      Yeah, i hate to ask that type of question here, but I was just debating options.
      My father has a 64 small block, nothing special, just a 327/250hp car, which the 68 radiator is currently installed in. I am doing some work on the car for him and i need to remove the radiator. The 68 radiator works great and the car never runs above 180, but since it is an original 68 radiator, i thought it might have value and if so, then i was going to consider selling it for him and buying a direct fit replacement from dewitts. however, something tells me that i will not get the 550.00 for the 68 radiator to offset the cost of a direct replacement, so it's probably best to just keep using this radiator.
        • 6948
        Chris the C3 cars seem to have a little more air flow than the C2 cars. A partly plugged system would like overheat in a C2 car.
        • Christopher A.
          • February 13, 2009
          • 167
          As i mentioned in my second post, which might not have been up when you responded, the 68 radiator is currently installed in a 64 and it works great.
          I wasnt aware of any drastic differences in the 327 radiator design from the c2 to the c3 model. I thought they were all basically the same.
            • 6948
            Chris, Did not catch that, sorry, the radiator is the same basic design I believe. as for the part no. I AM not sure.
            • Christopher A.
              • February 13, 2009
              • 167
              I just know it is dated, but it appears to be the same design.
