DC Ralley - Anyone ever see this? - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    I recently purchased a DC Ralley. Its an original rim with the big DC stamp. Upon looking for KH stampings on the bead, I found this....
    Best,
    Dave
  • Jeff P.
    • October 21, 2011
    • 287
    Re: DC Ralley - Anyone ever see this?
    Can't say that i seen that Kelsey tag before, but i've seen the chrysler pentagon stamped on a rim. I thought that was different.
      That's a Kelsey-Hayes wheel sold through their aftermarket retail channel.
      • Peter L.
        • May 31, 1983
        • 1930
        Dave - I have several of these wheels with the tan paint on the inside but not a tag like yours. The wheels I have are dated 11 67 inside the rim by the the other stampings so as John mentioned that are either SERVICE wheels or they could also be Camaro wheels because if the date stamping and I think they were used on the 67-68 Camaros.
        Check yours for the manufacture's date stamping and see what you find. If it's later then 67 Corvette production wheels it will function fine and only you will know.
        Pete
          • 43271
          Best,
          Dave
          Dave-----
          As John mentioned, these are Kelsey-Hayes wheels sold through their own aftermarket channels as opposed to those supplied to PRODUCTION or GMSPO.
          So, what's the difference between these wheels and those supplied to GM for either PRODUCTION or SERVICE purposes? Well, USUALLY, those supplied to GM will be stamped "GM" somewhere on the wheel.
          • Bill W.
            • March 1, 1980
            • 2000
            Steve Walker had one or two of them on his 67. We found out they were K.H over the counter wheels. Seems like the DC was a different size ?
            • David S.
              • August 9, 2009
              • 595
              The rim says GM in the center behind where the center cap goes...
                • 43271
                David-----
                That's usually where it's at. You won't find this on wheels sold through Kelsey-Hayes aftermarket although the wheels were otherwise the same.
