C2 Non-Posi rear end fluid - NCRS Discussion Boards
+ More Options
Posts
  • Al R.
    • June 30, 1988
    • 688
    Anybody know what type of grease/oil goes into a non-positraction rearend and the required amount of such. 1967. Can't find my notes on it TIA
  • Ridge K.
    • May 31, 2006
    • 1018
    Re: C2 Non-Posi rear end fluid
    Al, is your's a factory non-posi?
    I haven't seen many.
    According to factory production stats, they only built 2,632 without a posi rear.
    Ridge
      • 15706
      SAE 80W-90 GL-5 gear oil. Brand is not important, just the SAE viscosity and API GL-spec.
      The approximate capacity is 3.7 pints.
      (Same oil for manual transmissions - about 2.5 pints for four-speeds.)
      Postraction axles use the same oil, but need the friction modifier additive to prevent clutch chatter.
      • Al R.
        • June 30, 1988
        • 688
        Thanks Duke, and Merry Christmas to you and the family!!
