Tank Sticker Locations (1972) - NCRS Discussion Boards
    • May 31, 2002
    • 169
    On top of tank. Which side of tank is sticker located?
    Can it be seen with small light and mirror?
  • Dennis B.
    • December 1, 2011
    • 92
    Re: Tank Sticker Locations (1972)
    My 72 tank sheet was located on the top of the tank on the Passenger side of the tank.
    If you crawl under the car reach over the tank you may feel it. Odds are its covered with dirt and grime so you will not be able to read it.
    You could try pulling back the over flow cup on the Gas filler and shine a light in to see if you can see it.
    • Patrick B.
      • August 31, 1985
      • 1995
      The tank sticker on my 70 was in the same place, and it could certainly be seen by removing the gas filler door and rubber overflow cup.
      • Dennis B.
        • December 1, 2011
        • 92
        I think the guy that owned mine lived on a muddy road, I used a blow dryer and chipped the crap off of the tank sticker to read it. I had to remove the tank because one strap had snapped.
        • Mike M.
          • May 31, 1974
          • 8389
          both of my 67's had the sticker on the top drivers side of the tank and could be viewed by removing the filler neck rubber. couldn't read it without taking tanks down though.mike
          • Patrick T.
            • September 30, 1999
            • 1286
            Same here, I was amazed at how legible the sticker was after spending most of it's time in West Virginia, the rust belt. Still had to drop the tank to read anything though.
            • Jim T.
              • March 1, 1993
              • 5351
              My 70's tank sticker is on the drivers side of the tank. Also I found the order copy located above the tachometer.
              • Jack C.
                • September 30, 1992
                • 1090
                On my 68, it was on the driver's side of the tank.
                Jack Corso
                1972 Elkhart Green LT-1 Coupe 43,200 miles
                Top Flight 1994, 2018 & 2021
                  • May 31, 2002
                  • 169
                  Thanks for the response from each of you. My main inquiry was to understand
                  if a certain side was used through out the production year.
                  I have a copy of my tank sticker which was found in the car back in 1972.
                  I continue to learn more about our cars via the NCRS Discussion Board.
                  A big thanks.....
