When judging the door panels on a 70-72 car that has the deluxe door panels. What is the determining factor that judges look for in the reproductions vs. a pair of NOS or a pair of reskined . What tell tell signs would one see in order to knock off points on any one of those panels?
Door panels
Re: Door panels
most cheaper repros are made from ABS plastic. Plus the wiskers are riveted not stapled.
The originals are made from a white/cream fiber board and can be detected. The wiskers are stapled with a 5/8" wide staple.
NOS ones should be darn close to originals and pass just fine.
As for repros - Al Knock can made fiber board door panels - they run around $500 per side to do, and look perfect ( I did this with my 72').- Top
Re: Door panels
Bill is correct about what interior judges look for. Knoch's are the closest repros out there. But there is one more thing on custom panels: as far as I know, no one is doing real wood for the inserts.
I have a pair of NOS panels bought in the late 1980s and they have vinyl not the wood veneer. Maybe Joe can tell us if service panels ever had real wood. I know the separate inserts that were available across the counter were vinyl.
Hopefully, your old panels have the wood insert that can be transferred to new ones.- Top
Re: Door panels
How are the ones with ABS backing detectable? Do you know of any one that reskins the door panels , my drive side is panel has the skin coming up were the elbow arm rest is. Other than that the panels is perfect I wonder if someone could repair it?- Top
Re: Door panels
Al Knoch's fiberboard backed panels are very nice, as others have said. Don't forget the vapor barrier though as they are easy for a judge to see. I don't know if anyone is doing the vacuum molded barriers or not.Kramden- Top
Re: Door panels
I can take my little finger and feel the back of the door panel. Takes all of about three secondsDick Whittington- Top
Re: Door panels
I used balsa wood stained to correct shade and then shellac then sand until desired finish and it was undetectable from originalMichael
70 Mulsanne Blue LT-1
03 Electron Blue Z06- Top
Re: Door panels
Hi,
I don't believe anyone is reproducing the vapor barrier from the original material and in the vacuum formed manner. Some barriers are being sold but they are flat, and a different material.
Michael, that must have been an interesting piece of work! I'd love to see a picture of the results.
AlanAttached Files71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
Re: Door panels
Lyndon
One other option maybe an automotive vinyl repair specialist. I have seen them at work doing repairs on seats and other interior parts. Once completed it was hard to detect where the repair was done. A competent specialist could tell you if the repair is possible or not in a few minutes. If your only problem is the arm rest area they maybe be able to help you maintain those original door panels. It is very typical for that area to be damaged on the drives side and the passengers side almost perfect someone is always in the drives seat when the car is out.
Many dealerships use them so you maybe able to find one through you local dealership service department. Or a local automotive interior trim shop plus most of them will come to the car for the repair.
Paul 18046- Top
Re: Door panels
As Paul said, they can often be repaired.
If the rest of your interior is original then I'd leave them alone.
If the rest of it has been restored then buy 2 panels and be done with it.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Re: Door panels
If the panels are good except for one place on the arm rest, I would take the deduction for condition. It will probably be less than the originaliity lost for reproductions, and you will get those deductions on both doors. I have been driving my 1972 for several years with an armrest patch panel.- Top
Re: Door panels
Really? Do I run the risk of a judge sticking a finger in my door? I'll have to file the metal edges razor sharp! Watch where you put that finger!
'73 LS-4 454 owned 21 3/4 years- Top
