New Bias Ply Tires - BFG Silvertown 660 - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    I'd like to put a set a BFG Silvertown white line tires on a 67 to be judged. Are the BFG 5/8th while line tires (7.75x15) from Coker Tire the best BFG's to use?
    Dave
  • Steve B.
    • March 1, 2002
    • 1191
    Re: New Bias Ply Tires - BFG Silvertown 660
    David, the reproduction BFGs do not say 660 on the sidewall. If you want to use BFGs, then you have to use the silvertowns. I would guess that you will receive the standard 3 point deduct for the tires.
    • Dick W.
      • 10483
      Steve, et al, at one time there was an issue with either the tread design or the nomenclature on the side of the tire. I would check with the appropiate Team Leader
      Dick Whittington
