"Check Guages" - NCRS Discussion Boards
"Check Guages"
  • Jim T.
    • March 1, 1993
    • 5351
    "Check Guages"
    Anyone experience a "Check Guages" illumination light on the dash and the gas guage not working with a full tank of gasoline on a C4? My C4 is a 1996 LT4 coupe that has this problem. Occured today, first time to use the car since August 21, 2011 when I filled it with gasoline.
  • Arland D.
    Moderator
    • July 31, 1980
    • 429
    Re: "Check Guages"
    Jim,
    I drove the 94 until the tank was down to fumes and got a chime and check gauges message. I believe the other gauge readings were all zero's because the car was desperately trying to tell the driver to get some gas. Me thinks your sending unit is telling the ECM it is empty or close to it.
    Arland
    • Ken A.
      • July 31, 1986
      • 929
      Re: "Check Guages"
      Gauge functions are sent thru the BCM, not the ECM.
        • 6956
        Re: "Check Guages"
        Hi Jim,
        The check gage warning will come up anytime a any gage goes out of the normal working parameters, A gas gage that is sitting on empty, or a temp. gage showing overheat, low oil pressure. will give you a warning on the dash. and some years you will get a chime warning also.
        • Keith B.
          • March 7, 2008
          • 928
          Re: "Check Guages"
          when the gas gauge reads low below two bars it should say reserve. I had it down to one bar before and the check gauge light never came on. this is on my 94 LT-1
          • Pat M.
            • April 1, 2006
            • 1582
            Re: "Check Guages"
            Yup, same on my 96 LT4.
            • Arland D.
              Moderator
              • July 31, 1980
              • 429
              Re: "Check Guages"
              The gas gauge generally won't set the check gauge warning until it is less than one bar and almost completely out of gas.
              • Jim T.
                • March 1, 1993
                • 5351
                Re: "Check Guages"
                Took the 96 on a long trip Monday the 19th, after insuring the tank was full on the 18th. The gas guage was not showing any level, the "reserve" was showing, and the "check guages" was illuminated when I left. About 28 miles down the road the "check guages" went out and the guage read a full tank. The guage was very slow moving from full on the trip. Put 280 miles on that tank of gas and the guage was showing about 3/4 of a tank. Put 9.7 gallons of gas in and drove 288 miles today. The working guage showed full starting the trip and was down almost to 3/4 full after 288 miles and took 9.8 gallons to fill up. Strange to drive almost 220 miles on a fill up and the cars computer saying you can go 512 more miles.
                  • 6956
                  Re: "Check Guages"
                  Jim. sounds like a fuel sender thats gone aray, The newer ethanol fuels tend to do something to the older GM senders.The wiper board must have something that the ethanol will break down.
                  • Bill H.
                    • August 8, 2011
                    • 439
                    Re: "Check Guages"
                    That may be possible, Edward but, just to note, I've been running ethanol in my 92 for 6 years with zero problems.
                      • 6956
                      Re: "Check Guages"
                      Bill, some of the new fuels contain sulfur that are attacking the 2006 and older fuel senders, GM does sell a additive to help with the problems.this was a GM bulletin.
                      • Bill H.
                        • August 8, 2011
                        • 439
                        Re: "Check Guages"
                        Understood and and I wasn't disputing your origional point. just making an observation.
                        I hadn't heard about the TSB, good to know.
