Headlight problem - NCRS Discussion Boards
Headlight problem
  • George F.
    • May 5, 2011
    • 4
    Headlight problem
    Hi; I'm having a problem with the low beam headlight on my 67. The passenger side light is out when on low beam, but all four light up when the high beams are on. I've replaced the light and it didn't help. So, it seems to me that fuse, bulb, ground and wiring are okay. Does anyone have an idea for me to try? Thanks for any help.....
    • 6956
    Re: Headlight problem
    Greoge, the low and high beams on the drivers side have wires that feed the pass side headlamps low and high. check the wires on the driver light.Maybe a broken wire.
