Foil label on 67 w A/C - NCRS Discussion Boards
  • Al R.
    • June 30, 1988
    • 687
    Hi guys, could use some immediate help on the correct location of a foil decal "HARRISON Air Conditioning 3012644 SAE-AIR-60". I removed while restoring my air cond. evaporator box. I took close-up pic's of the label, however I took them too up close and now can't tell from the pic,s and don't have enough memory left to know exactly where it goes. I'm thinking somewhere on the top or bottom of the evap. coil itself. Any quick help would be most appreciated as I'm in the shop trying to get it back together as I type this. TIA Al
  • Al R.
    • June 30, 1988
    • 687
    Re: Foil label on 67 w A/C
    Never Mind! I got out a magnifying glass and was able to see a faint imprint of Harrison on coil. It was located between the mounting bracket and the large refrigerate pipe.
    • Jim S.
      • March 1, 1986
      • 1408
      Al,
      If this helps any , and you have not already installed it . I don't have a pic with me, but there is one from a previous post titled : AC hose retainer on fender tub location , dated 12/11/2010 . Jim
