'57 Exhaust System - NCRS Discussion Boards
'57 Exhaust System
  • Wayne G.
    • April 30, 1984
    • 143
    '57 Exhaust System
    I will need to replace the complete exhaust system in my '57. The car will be flight judged so I would like to get some member input on what reproduction exhaust system will come as close to original as possible.
    Wayne
  • Gary C.
    Administrator
    • October 1, 1982
    • 17648
    Re: '57 Exhaust System
    Wayne,
    Easily installed Corvette Central's system on my '57 with no fitting problems whatsoever.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Wayne G.
      • April 30, 1984
      • 143
      Gary,
      Thanks for the advice, I'll check out their system..
      Wayne
      • Tom S.
        • August 31, 1994
        • 137
        Like Gary, i used the same system. After installation, i went to a buddie at a muffler shop to have the system tweaked a bit to solve some clearence issues. See page 93 of the JM re: blackout of the system, fine threads natural steel U-bolts and ground strap useage. Mine were too long and I used a tube cutter to trim the excess off to a finger width. I see lots that are flush but you need the little extra to prevent the water from spitting out on the chrome.
        • Wayne G.
          • April 30, 1984
          • 143
          Tom,
          That's good advice. I follow the JM and AIM as well as I can and will use
          NOS or very good used GM parts as much as possible.
          But in the case of the exhaust system it's always good to ask advise on components that almost always have to be reproduction. I've looked around for some NOS '56-'57 exhaust without any success. So Repo it is.
          Wayne
