Cad plating - NCRS Discussion Boards
Cad plating
  • Jason W.
    • February 1, 2011
    • 46
    Cad plating
    What are people doing to get cad plating anymore? Seems most shops don't do it. Anyone try this: http://www.caswellplating.com/kits/copycad.htm
  • Robert M.
    • January 1, 1992
    • 78
    Re: Cad plating
    Hi Jason;
    I have Caswell's 3 gallon kit , works great I also use their brightner with it.
    • Gary B.
      • February 1, 1997
      • 7046
      Re: Cad plating
      Jason,
      If you want to send your parts out for plating, I'm sure Richard Fortier (contact info in the Driveline) can arrange to have cad done.
      Gary
      • Michael M.
        • February 1, 1993
        • 604
        Re: Cad plating
        Jason, in a recent previous post Rich Pasqualone and Dennis Crupi mention Manco Plating on the East Coast. If you live near the East Coast you might save some money instead of sending your stuff to Richard Fortier. Richards prices are a little dear compared to other platers.
        • Peter J.
          • September 30, 1994
          • 586
          Re: Cad plating
          Jason,
          I have used these guys a couple of times and been happy with the results and prices:
          Aero Propeller & Accessories, Inc.
          9616 Jeffco Airport Ave., Hangar 44
          Broomfield, CO 80021
          800-525-8756
          • Jerod M.
            • March 10, 2011
            • 95
            Re: Cad plating
            I have the caswell kit and a power supply off of ebay
            • Gary C.
              Administrator
              • October 1, 1982
              • 17768
              Re: Cad plating
              Check aircraft repair shops in your area and find out where they get the CAD work done. Aircraft guys still CAD lots of parts.
              Gary
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • Tony S.
                NCRS Vice President, Director Region VII & 10
                • April 30, 1981
                • 989
                Re: Cad plating
                Detray Plating in Kansas City area still does full service cad plating.
                Tony
                Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
                Original member of the Kansas City Chapter, est'd 07/11/1982.
                Member: 1965 and 1966 National Judging Teams
                Judging Chairman--Kansas City Chapter.
                Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
                • Gerard F.
                  • June 30, 2004
                  • 3806
                  Re: Cad plating
                  Jason,
                  I have been using the Caswell copycad plating for a number of years and I started with a 3 gallon kit. They call it copycad, as it is really zinc plating made to look like cadmium.
                  The yellow look which most people call cad is actually a
                  dichromate dip of the zinc plating. A little more dulled zinc plating actually looks like silver cadmium plating. After a little weathering, it takes an expert to tell the difference.
                  Most older parts and all reproduction parts are zinc plated instead of cadmium plated. If you search the archives, there is a number of discussions over whether an old part was zinc or cadmium plated. I think that the truth is that it was optional on the vendor, zinc or cadmium back then. Maybe certain parts subject to servere corrosion were spec'd as cadmium plating.
                  Cadmium at the present time is a very controlled material thanks to the EPA and many State Water Quality regulators. It has a disposal problem for commercial platers. But you still see aircraft industry platers and a few others, doing cadmium plating. But the regulatory and disposal costs would put a hobbyist out of business.
                  With that said, I have a still do a little real cad plating as a hobbiest with an older spent caswell solution. The cadmium anodes can be obtained.
                  But if you use the caswell copycad with the brightener, and the yellow chromate solution where applicable, nobody will be able to tell the difference. I actually prefer the zinc plating with the brightener for a nice bright finish, and that yellow gold on parts.
                  If you want to do it yourself, I'd go with the caswell copycad. Figure about $500 for starters, to get into it, plus a ventilated corner of your garage.
                  But it's a great hobby.
                  Here's what you can do with the caswell kit:
                  and this:
                  Jerry Fuccillo
                  • Susan M.
                    • January 10, 2011
                    • 63
                    Re: Cad plating
                    Hi Jason, I see you are in CA. Valley Plating in Santa Clara does cad plating. They have a $185 minimum. I have used them for chrome and zinc so far with excellent results. Ask for Fred. http://sjvalleyplating.com/ . Are you in northern CA? They will ship too. Good luck. Susan
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      Re: Cad plating
                      There are still many shops that do this at a much more affordable entry point - less that $100 for all you can do, essentially. But I ask you why bother?
                      #1 most the parts were zinc back then, it was only certain parts that got cad specified, and then again, if you are with a garaged car, zinc is more than adequate if you go with the original specification.
