Ok, so the bolt of the day game failed a while ago, so ive changed the name for the bolt threads.
I have been over the car and i am still clueless as to where most of these bolts go, even after looking over another 66 that is fairly unmolested.
-This is a WB bolt with 5 marks on the head, which I presume means it is grade 8.
-It looks identical to the bolts that mount the front bumper to the bumper brackets which mount to the front crossmember of the frame, except it is longer and has a portion that is unthreaded.
Possibly the transmission mount bracket where it bolts to the crossmember. Can somebody verify what that specific bolts headmark should be?
BTW, i put the new black phosphate coating on the bolt and i believe it to be correct for this particular bolt.
