1958 "Gullwing" Heater Hose Bracket - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    In the assembly manual and in all parts catalogs there is only one of the "Gullwing" or double U shaped bracket that holds the heater hoses which is located on the passenger side of the engine compartment, right above the battery. My early 58' has two. The second is very close to the voltage generator. I see that 57's had two also. Any input on this?
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 1958 "Gullwing" Heater Hose Bracket
    Justin,
    Well here is some info about 1 year after your posting...
    My early 57 has 3 of the double hose brackets holding the heater hoses in place on the right inner fender.
    2 are below the fresh air hose and one above the battery.
    See attached pictures.
